Question on Aventum X Cooling
Post Date: 2021-10-21
Noodle4U2 View Drop Down
  Quote Noodle4U2 Quote  Post ReplyReply bullet Topic: Question on Aventum X Cooling
    Posted: 21 Oct 2021 at 9:28am
Hi Everyone,
I just purchased an Aventum X, and am super excited. Have been building PC's for 20 years, and custom water-cooled PC's for 10 years, and figured it was time to let someone else do it lol. I have a few questions on the Hydrolux water-cooling setup. Brief specs overview below:
5800x
3090
850w PSU (have a 1500w ill be adding to it)
Exotic Cables
Hydro Lux Cooling on CPU/GPU with Clear Hard Line tubing
I have found conflicting info on how many radiators are included in this beast. Is 2x560mm and 1x280mm correct? Does this change if you only elect to get one GPU? I selected the option to water-cool both CPU and GPU. I have a 3090 from my current build that I am planning on adding to the system, so I want to be sure that the amount of radiators is not impacted by the number of GPU's selected.
Also, I chose the clear hardline tubing. Is this PETG, or Acrylic?
Thanks everyone, I appreciate the help! Super excited to join the community.
JamesAstro View Drop Down
  Quote JamesAstro Quote  Post ReplyReply bullet Posted: 21 Oct 2021 at 11:37am
I had an Aventum 3 from 2015, and it had 3 radiators: 560mm, 420mm, and 280mm.
The machine had 3 liquid cooled 980 Ti cards when it was built. I'm not sure if the number of radiators varies from machine to machine though.
MrCheetah View Drop Down
  Quote MrCheetah Quote  Post ReplyReply bullet Posted: 21 Oct 2021 at 2:11pm
From the Aventum X product page:
Originally posted by Digital Storm
Boasting the ultimate liquid cooling loop for excellent thermals, Aventum features 560mm radiators located at the top and bottom and a single 280mm radiator near the power supply.
  Quote Noodle4U2 Quote  Post ReplyReply bullet Posted: 21 Oct 2021 at 2:38pm
Originally posted by MrCheetah
From the
Yeah I saw that on the product page, just wanted to confirm that didn't change based on configuration. There are only a handful of reviews on this monster, and each of them list different radiator specs, so just wanted confirmation :). Thanks for the response!
  Quote MrCheetah Quote  Post ReplyReply bullet Posted: 21 Oct 2021 at 4:52pm
I assume, your doubt/confusion is due to examples such as...
UNBOXING the GOD OF GAMING PCs!! | Linus Tech Tips (YouTube)
... Where Linus seems to conclude the top radiator is a 420mm rad, not a 560mm.
I can't tell/verify via that video nor the marketing photos the size of the top radiator.
Beyond your curiosity, I think, you'll be totally fine with 140x1260mm (560+420+280) or 140x1400mm (560+560+280) equivalent radiator cooling.
People run CPUs cooled by 120x240mm rads or 120x360mm rads with plenty of headroom. And the EVGA RTX 3090 K|NGP|N seems to do okay with a 120x360mm rad plus the 80mm or whatever fan that's on the card. So, 120x720mm total... say 120x840mm with the graphics card heatsink.
But... I'm not a custom loop enthusiast and just doing the simple math comparison.
Edited by MrCheetah - 21 Oct 2021 at 4:56pm
