Tripple Monitor gaming/recording Desktop Parts
Post Date: 2015-12-10
Ace-of-Spades View Drop Down
  Quote Ace-of-Spades Quote  Post ReplyReply bullet Topic: Tripple Monitor gaming/recording Desktop Parts
    Posted: 10 Dec 2015 at 2:10am
$3000-$5000 CAD
I want a computer that can run three LG 34UM67 Ultrawide Monitors.
Be able to record all three monitors and game at the same time.
Recording/Gaming
I personally am a complete noob to choosing PC parts so help is greatly appreciated.
 View Drop Down
  Quote  Quote  Post ReplyReply bullet Posted: 10 Dec 2015 at 11:12am
You're going to want the 12 GB VRAM of the Titan X for this configuration.
a) Try a video capture software that uses Intel Quicksync on the iGPU to unload some of the major encoding work from your other hardware. You can use something like Predator in MSI Afterburner or Open Broadcast Software for this. Here is a quick video on how to set up OBS to use Quicksync.
or b) If that doesn't work, you may want to consider getting a dedicated hardware solution like: Avermedia, Hauppauge, or Elgato.
I'm not sure if any recording device/service will do triple screen recording, you're going to have to look into that. Most I am aware of will only do a single 1920x1080 recording at the most.
Configuration URL: https://www.digitalstorm.com/configurator.asp?id=1335627
Chassis Model: Special Deal Hot Seller - Digital Storm Coridium
Processor: BACKORDERED ETA Early January: Intel Core i7 6700K 4.0GHz (Unlocked CPU) (Quad Core)
Motherboard: ASUS Z170 PRO GAMING (Intel Z170 Chipset) (Up to 5x PCI-E Devices)
System Memory: 16GB DDR4 2666MHz Digital Storm Certified Performance Series
Optical Drive: - No Thanks
Storage Set 1: 1x SSD PCI-E Card (400GB Intel 750 Series) (NVM Express) (Extreme Performance)
Storage Set 2: - No Thanks
Graphics Card(s): 2x SLI Dual (NVIDIA GeForce GTX TITAN X 12GB (EVGA HYBRID Edition)
Extreme Cooling: H20: Stage 2: Corsair H110i GT - 280mm Radiator Liquid CPU Cooler (Extreme Performance)
H20 Tube Color:- Not Applicable, I do not have a custom HydroLux liquid cooling system selected
Airflow Control: - No Thanks
Boost Processor: Stage 2: Overclock CPU - Up to 4.8GHz (Depends on Cooling and Motherboard)
Portable Gaming: - No Thanks
Branded Gear: - No Thanks
Edit: this will be a little more than your budget due to the currency conversion, but really is what you'd need to run this sort of configuration.
Edited by  - 10 Dec 2015 at 11:13am
db188 View Drop Down
  Quote db188 Quote  Post ReplyReply bullet Posted: 15 Dec 2015 at 9:34pm
keep in mind i have no personal experience with this myself, but i've read user opinions on this subject, and more than once i've read that capture cards work great when used in conjunction with consoles or another computer, however, if you're recording and playing off a single computer they don't really help.  it's best just to go with HEDT procs (6 and 8 cores) and lots of vid card vram.
Aventum 3
I7-6700K
Gigabyte G1 Z170X Gaming GT
Corsair Hx1000i 1000W
Gigabyte M28U 4K
