How to create motion effects for videos?Post Date: 2021-09-29 |
Post Reply ![]() |
JodyPayne ![]() Newbie ![]() Joined: 27 Sep 2021 Online Status: Offline Posts: 1 |
![]() ![]() ![]() Posted: 29 Sep 2021 at 12:28am |
NEX Mini Sewing Machine Review
Teaching kids how to sew can be challenging as most of the machines that an adult is comfortable using may not fit a child. But the NEX portable sewing machine is designed just for the job. The size is scaled down, and the functions are simplified, making it the perfect option for a kid. The Basics With NEX, you will have all of the basics. There is no complicated or fancy features that may confuse someone new to sewing, making it the ![]() ![]() With NEX, you will have all of the basics On this machine, two most advanced features are the thread cutter and the bobbin winder. The top-drop bobbin also makes things a lot easier for users. NEX has two-speed options, only one stitch, and no reverse function, but it offers the choice to sew with either the button or the foot pedal. The machine has an inbuilt LED light so that users can see everything clearly. Safety First What most people worry the most about teaching a child to sew is that the needle may hurt their fingers. But NEX has just the feature for that. There is a safety cover around the needle to prevent users’ hand getting caught in the needle. Comes With Everything You Need NEX sewing machine comes equipped with everything a beginner needs, and it can be powered by either electricity or a battery. Having two options for powering is excellent as your child may want to bring his or her machine on vacation or to a friend’s house. If you ever wonder how to buy a sewing machine for beginners ![]() There is one issue though. Since there is no reverse function, the seams can easily be undone. However, as this is a sewing machine for children, you cannot expect much from it. If your child shows real interest in sewing or they gain enough skills for more serious projects, you can always upgrade to a more competent machine later. ![]() There is a safety cover around the needle to prevent users’ hand getting caught in the needle While it is possible for the machine to use two sources of power, if you plug it in while the batteries are still inside, you may end up damaging it. This is even more serious with a child; he or she may forget about the batteries. While some of the disadvantages might sound serious, the NEX sewing machine is still a reliable option for beginners who need an affordable model to start with the basics of sewing. It is also an excellent gift for a child who has just begun to take a liking to this hobby. The fact that this machine comes with only the most basic functions means that your child can focus more on mastering the simplest and most fundamental parts of sewing before advancing more. All in all, if this NEX sewing machine is not the ![]() Edited by JodyPayne - 18 Jun 2022 at 8:13am |
JamesAstro ![]() Groupie ![]() ![]() ![]() Joined: 28 Nov 2008 Online Status: Offline Posts: 492 |
What kind of animation are you trying to create? Are you simply trying to animate a title or a transition? Or are you trying to create some kind of animation from scratch, and then export that to a video?
32GB RAM, 1TB Samsung 980 Pro NVME RTX 3090, 38" Ultrawide LG-38GL950G Noctua NH-D15S cooler and NF-A14 fans, Corsair AX1600i PSU |
Post Reply ![]() |
Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
